LUXOR is a newly designed 48-inch light bar with the latest high intensity LED modules which are 20% brighter. The ultra slim low profile makes the light bar almost invisible. LUXOR produces an ultra bright beam of light that will be seen 360 degrees even in bright daylight. Built with the latest features that are required by emergency responders. The switch controller is the commend center of the light bar controlling all functions. The controller has an LED display showing the operator the flash pattern in use.
Features
