Rigid Industries High & Low Dual Function LED Lights provide the option of high or low intensity LED lighting to suit any environment. These lights feature a three-wire harness and the low high or off three-position rocker switch which gives you the option of running at full intensity on high power or 20% intensity on low power. The Rigid Industries High & Low Dual Function LED Lights feature a thermally engineered oversized heat sink that provides the cooling power to deliver the 50000-hour lifespan. With its unbreakable polycarbonate lens durable UV-resistant powder-coat and patented optics the High & Low Function LED Lights are the total lighting solution. Torture Tested and Approved.
Features
