ECCO ECC5590CA-VM 15 IN. TIR OPTIC LED EMERGENCY LIGHT CLEAR AND AMBER
Universal Reflex Vacuum-Magnet Mount 15 Clear Dome Amber TIR Optic LED Emergency Light (5590CA-VM) by ECCO. Reflex LED minibars provide a compact yet powerful warning solution that features 12-24 VDC operation uses high intensity Reflective and TIR Optic LED modules to maximize light output and allows the user to select from a choice of 18 user selectable flash patterns.
Features- Combines Reflective and TIR Optic LED modules to optimize focused front/rear warning and wide-angle side warning
- Cigarette plug with on/off and flash pattern selection switch
- Made using the breakthrough technology
- Effective innovative and extremely robust
- Maximum protection and improved safety
Specifications- Color: Clear & Amber
- Voltage: 12-24 V
- Flash Pattern: 18
- Temperature Range: -22F to +122F
- Ampere: 6 A
- Weight: 5.7 lbs
Price: 605.49
