ECCO ECC5585CAB 15 IN. LED CLEAR LENS EMERGENCY LIGHT BLUE AND AMBER
Universal Reflex 5585 Series 4 Bolt Mount 15 Amber/Blue LED Clear Lens Emergency Light (5585CAB) by ECCO. SAE Class I. Reflex LED minibars provide a compact yet powerful warning solution that features 12-24 VDC operation uses high intensity LEDs and reflective technology to maximize light output and allows the user to select from a choice of 18 user selectable flash patterns. Permanent mount models are synchronizable with each other.
Features- Eight LED reflector modules each comprising three LEDs provide high intensity light output
- Polycarbonate base & low profile lens
- Made using the breakthrough technology
- Effective innovative and extremely robust
- Maximum protection and improved safety
Specifications- Color: Blue & Amber
- Voltage: 12-24 V
- Flash Pattern: 18
- Flash Rate: Varies
- Temperature Range: -22F to +122F
- Ampere: 5.1 A
- Weight: 3.4 lbs
Price: 502.40
