ECCO ECC15-00038-E 54 IN. 14 LED EMERGENCY LIGHT BAR WITH TIR OPTIC LED MODULES AMBER
Universal Streetlazer 15 Series 54 Amber 14 LED Emergency Light Bar with TIR Optic LED Modules (15-00038-E) by ECCO. Low profile 12VDC quad flash. This product is made of high-quality materials to serve you for years to come.
Features- Aluminum base
- Made using the breakthrough technology
- Effective innovative and extremely robust
- Maximum protection and improved safety
Specifications- Color: Amber
- Voltage: 12 V
- Flash Pattern: Quad
- Flash Rate: 80 FPM
- LEDs: 5 Front/5 Rear/4 Corner
- Temperature Range: -22F to +122F
- Ampere: 2.9 A
- Weight: 35 lbs
Price: 3199.76
