ECCO ECC15-00037-E 49 IN. 16 LED EMERGENCY LIGHT BAR WITH TIR OPTIC LED MODULES AMBER
Universal Streetlazer 15 Series 49 Amber 16 LED Emergency Light Bar with TIR Optic LED Modules (15-00037-E) by ECCO. 16 module with integrated LED Safety Director low profile 12VDC quad flash. This product is made of high-quality materials to serve you for years to come.
Features- Aluminum base
- Made using the breakthrough technology
- Effective innovative and extremely robust
- Maximum protection and improved safety
Specifications- Color: Amber
- Voltage: 12 V
- Ampere: 3.2 A
- Flash Pattern: Quad
- Flash Rate: 80 FPM
- LEDs: 4 Front/8 Rear/4 Corner
- Auxiliary: 8 LED Safety Director
- Temperature Range: -22F to +122F
- Weight: 34 lbs
Price: 3735.83
