ECCO ECC15-00035-E 39 IN. 8 LED EMERGENCY LIGHT BAR WITH TIR OPTIC LED MODULES AMBER
Universal Streetlazer 15 Series 39 Amber 8 LED Emergency Light Bar with TIR Optic LED Modules (15-00035-E) by ECCO. Low profile 12VDC quad flash. This product is made of high-quality materials to serve you for years to come.
Features- Aluminum base
- Made using the breakthrough technology
- Effective innovative and extremely robust
- Maximum protection and improved safety
Specifications- Color: Amber
- Voltage: 12 V
- Ampere: 1.6 A
- Flash Pattern: Quad
- Flash Rate: 80 FPM
- LEDs: 2 Front/2 Rear/4 Corner
- Temperature Range: -22F to +122F
- Weight: 30 lbs
Price: 1921.02
